Old 10-27-2009, 04:09 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968-70 4 Bolt 396 Blocks, Heads and Parts
1968 396 4 bolt standard bore block with two sleeves pressure tested good dated E-21-8 with casting number 3965440 and front pad of T0524MQ 18N449843 $1250.
1968 3919840 square port heads rebuilt dated F-17-8 and F-18-8 $1500
1968 3919840 single square port head bare cleaned and magged $650
1969 396 4 bolt standard bore block cleaned and magged casting number 395272 dated K-4-8 with original pistons, steel 6223 crankshaft and original 8 inch harmonic balancer $2250.
1969 396 4 bolt standard bore block casting number 3955272 dated E-23-9 with front pad of T0527JD 19B388171 and has been cleaned and magged $1750.
1969 3919840 single square port head complete dated C-25-9 $650
1969 3919842 Factory Aluminum square port heads complete with service dates on the top in excellent condition and the 1969 3955272 4 bolt L89 block 30 over ready for the final hone with front pad of T0527KG 19B400425 and is dated J-14-8 including the steel 6223 steel crankshaft $6500.
1970 List 4492 carb complete dated 993 for a L78 & LS6 application $600
1970 List 4492 carb dated 035 missing the choke, butterfly and correct primary 6328 metering block $500.
330-770-2517 if interested.
dlv4540 is offline   Reply With Quote
Old 10-30-2009, 07:54 AM   #2
mannymen
Liked 13 Times in 7 Posts
Default Re: 1968-70 4 Bolt 396 Blocks, Heads and Parts
would you be willing to trade the single 840 head for a 391 head?
N/A
mannymen is offline   Reply With Quote
Old 11-02-2009, 09:51 PM   #3
mannymen
Sent you a PM
N/A
Search this Thread:
Advanced Search
