Liked 32 Times in 19 Posts
Correct Air pressure before leaving the garage. If low fix the tire.... Pack bearings every year worked for me.
(Had an employee who felt a low tire should be just aired up for a trip not diagnosed result- blow out because lost air again on road)( on the road in Snow Storm to do a show) |
Liked 26 Times in 13 Posts
AMEN Dick Butler!! The pressure in these trailer tires is absolutely the most important aspect of towing our junk.
I'm unfortunate that I didn't do my research before buying my trailer and have two 5200 lb axles on a 26 footer. It came with Goodyear Marathon and I blew the hell out of tires trip after trip. I discovered this notice from Goodyear: http://goodyear.com/rv/pdf/marathon_gen_info_032806.pdf I run the 15" ST225 tire at 70psi cold. Since then I monitor the tire pressure EVERY time I stop and EVERY time before pulling out to or from a race. I even pull over into rest areas occasionally just to check the tires. Since then, I have not had a single blow out (knock on wood... next trip I'm doomed). I also try to pull no faster than 65, and NEVER go over 70 (fortunately my motorhome is hard pressed to go that fast unless its falling off a cliff). Next trailer will have the heaviest load rated axles and tires I can get even if I'm not hauling anywhere near the rated load. Don't skimp on the axles and tires!!!
Bill Harris ex 2172 STK ex 2272 S/S |
#3 | |
It might have been Jeff Teuton that said the cheapest 16 in. tire is better than the best 15 in. tire.
Joe Martens AA/Stock 3969 |
Liked 104 Times in 35 Posts
Bob please send me another email:
bobbybrannon@bbhac.com Seem to be having trouble with your email. Thanks
Bobby Brannon 4705 STK, SS |
Liked 325 Times in 50 Posts
Brannon, are you doing what I think you are doing? Don't I always buy your take off tires? If you help Bob, and using those would be a great help, I will forgive you, but you owe me a case -- cold.
Jeff Teuton 4022 STK |
A 2500 series Chevrolet with a 6.0L V8 towing capacity:
2WD w/3.73 Axle - 8,500 lbs. 2WD w/4.10 Axle - 10,500 lbs. 4WD w/3.73 Axle - 8,100 lbs. 4WD w/4.10 Axle - 10,100 lbs. A 3500 series dually/diesel w/4.10 Axle is good for 15,000 lbs. My brother and I had gone through the same thing you are going through. We bit the bullet and bought a nice used Chevrolet 2WD diesel dually crew cab pick up with 4.10 axle and are glad we did. We pull a 35ft. goose neck trailer. It has plenty of power and braking capacity. We weigh around 10,000 lbs, that includes car, trailer, and equipment. The added safety and piece of mind was well worth the money.
Nelson Kowal Stock 345 |
