#21 |
I thought Grumpy Jenkins always said a hot engine builds more HP?
#22 |
Liked 7,783 Times in 1,743 Posts
In an "ideal" situation you would want the shortblock and the combustion chambers hot and icicles hanging on the intake!
#23 | |
Now 0w is not uncommon.
Jeff Lee 7494 D/S '70 AMX |
#24 |
They were cooling his Pro Stock stuff down a couple of years ago just like everybody else. When that book came out everybody I know that tried it slowed down. He said he had a switch on his shifter that turned the water pump on in 2nd gear. We all went back to cooling them down. The all aluminium engines don't seem to care, and many actually like to run above 180 F. The LS1 is a great bracket engine because it makes the same power between 180 and about 210. I cool mine with a seperate battery to run the water pump and fans. Like Jeff mentioned, we often take it to the staging lanes to cool down for heads-up races.
Ed Wright 4156 SS/JA |
#25 | |
On all of our stuff filled with Hardblok the water cools down alot quicker. The oil temp will run a little hotter but we have no problems from Hardblok |
#26 |
Liked 126 Times in 20 Posts
I can tell you first hand that 10 qts over 5 will slow you down 3 tenths and almost 4 mph, Did it ,by accident, @ Indy a couple years back.
Tim Worner SS 1747 |
#27 |
Liked 427 Times in 97 Posts
#28 |
Liked 23 Times in 13 Posts
KIDZ, what do they know anyway!!! Still WET 6qts, back down da timing, and turn up da HEAT, works for me!!!
Frank Bialas 1570 STK |
