Liked 6 Times in 5 Posts
thank's Mark, from what you are saying the distributor is the heart beat of the engine?
Liked 26 Times in 13 Posts
I had a distributor gear shear the roll pin that holds it in place not too long ago. Right on the 1-2 shift. The car just nosed over and lost a ton of power. It didn't quit though since the gear spun on the distributor shaft a little but held at that point. The car would run but barely. I figured out what happened by putting a timing light on it and the timing had shifted from its usual 40+ degrees to around zero.
So if you did something similar, where the gear rotated on the shaft without free-wheeling, then it might have taken some timing out which would have slowed it down before it gave up entirely.
Bill Harris ex 2172 STK ex 2272 S/S |
hey Bill, the car backed fire out the exh and quit running, we put the distributor and find a lot of pin sherd off a 2 missing. checked out cam gear looked ok and put it back together start up and sounds good,and yea I change oil and going to start it up today and change again.
hey Bill and mark,the car ran great this weekend!!
