Sounds to me like you could have a bad ground and some wires crossed up in your plug. Had some of the same problems on my Goldrush this summer and spent 2 days trying to figure it out. Are your trailer wires color coded? If I remember corectly the yellow is left turn, the green is right turn the black is taillights, the white is ground the brown is running lights, the red is to charge the trailer battery and the blue is the trailer lbrakes. The ground wire (white) has to go into the center post of the plug. Hope this helps some.
Liked 333 Times in 180 Posts
Wayne just double checked the wiring on the PLUG---the colored wires are where they are supposed to be---the center wire position on the trailer plug has no wire attached to it --never did days its for backup lites-no wire in the harness is available to attach to it---I do not understand how you run a ground wire from the truck to the trailer when I think going thru the hitch ball would work but if that is not the case how do you ground the trailer to the truck or the trailer door to the trailer frame???( hinges on the trailer door metal on metal not a good enough ground???)---I'm game talk to me this is exasperating spent all day Sun futzing with this bout ready to completely rewire the frigging trailer get it over with BUT I dont wanna do that hafta pull the ceiling down etc.--- Keep those ideas coming ---Comp 387
Just try temporarily hooking a jumper cable from the truck frame to the trailer frame, to see if grounding is the issue.
Michael Pliska 643 S/G |
Liked 2,485 Times in 697 Posts
I agree... sounds like a ground wire problem for sure. The LEDS
are not as fussy as conventional bulbs. When the ground is bad my trailer do a lot of backfeeding and funny stuff. ![]() |
Liked 705 Times in 219 Posts
In about 1973,I worked for a gas station that had U-Haul rental trailers and trucks.You never saw junk until you saw their stuff. People used to rent a trailer, a clamp on bumper hitch, and wonder why the lights misbehaved. That was when bumpers had those big gas shocks suspending them, and continuity of ground wasn't too good to depend on. An auto electrician good enough to quickly diagnose and repair these issues that trailer lights can cause was enough of a rocket scientist that he didn't need to work there. Feed back through defective bulbs, sockets, and grounds would turn a saint into a drinking man. The suggestion to make sure all bulbs are correct for the socket is a good place to start. It might be necessary to remove all bulbs in the trailer, then re-install them one at a time until the glitch reappears. Good luck- it's probably something simple.
Liked 325 Times in 50 Posts
Ground the thing.
Jeff Teuton 4022 STK |
Liked 685 Times in 196 Posts
Liked 60 Times in 12 Posts
You can also use a good dielectric grease on the ball, after you clean off both surfaces. it will help with the round connection. Rust to rust doesnt make for good solid ground connections.
2894 STK |
It's more than likely a grounding issue from truck to trailer. This has happened to me before, but as soon as i started driving the ball and hitch made a good ground and it worked fine. Good luck!
Shawn
Shawn Blair 6383 SS 634 STK |
Liked 43 Times in 29 Posts
Make sure that your brake light bulbs are indexed properly. I have seen where it is possible to install the bulbs 180 degrees out and cause this condition.
Mark Ruset 2048 STK |
