Old 11-23-2009, 12:58 PM   #17
Bobby Brannon
Liked 104 Times in 35 Posts
Default Re: Trailer wiring ???
Do you have grease on your hitch ball. If you do you will need to ground the trailer. Then in trailer plug facing it about 5:00 is your ground.. Run wire from plug back to a good ground on trailer. Truck ground is at 7:00 make sure you have a good ground..
For Infro only
7 Way Plug Typical trailer wiring / position Knot on top at truck
Performance Trailer
Green is running lites / 11:00
Brown is right turn /3:00
Blue is brakes / 5:00
White is ground / 7:00
Red is left turn / 9:00
Black is a charging lite / 1:00
Yellow is back up / center
Bobby Brannon 4705 STK, SS
Bobby Brannon is offline   Reply With Quote
