Old 12-02-2009, 08:33 AM   #2
Liked 1,828 Times in 414 Posts
Default Re: transmission question
The TV cable on a 700 R4 MUST be adjusted correctly FIRST!
A properly built and adjusted car transmission will shift later than a truck transmission, gas or diesel.
An early upshift and no downshift is an incorrectly adjusted TV cable, or a screwed up transmission. Or both.
To make a transmission shift later, you remove weight from the governor weights.
I get $900 to build a good 700 R4 on the bench and have the converter rebuilt. And that's if there's nothing destroyed in the transmission to start with. If you got a good 700 R4 for $100, you got a killer deal.
