Liked 239 Times in 114 Posts
What transmission was originally in the Suburban ? The brackets that hold the tv cable are different for a 350 THM, so you need all the compatable parts. Carb, bracket, and the cable. The trans also shifts based on the output shaft rpm, for if the Camaro trans was set up for a 2.73, and your Suburban is a 3.73, the shift pattern will be way early.
