Old 12-07-2009, 10:27 PM   #1
stock eliminator
Default 12 bolt need help with I.D.
the tube is stamped KDC 251.. What's it out of?????
I have pic also
stock eliminator is offline   Reply With Quote
Old 12-07-2009, 10:33 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 12 bolt need help with I.D.
since it is out of a Chevelle that narrows the choices. Those were used from 1964 - 1972
The 1964 - 1967 were more narrow than the 1968 - 1972. So if someone knows the width of either the early or later, we will have the answer.
Larry Woodfin 471W
Old 12-07-2009, 10:34 PM   #3
stock eliminator
how do you know its out of chevelle?
Old 12-07-2009, 10:54 PM   #4
It is either out of a Chevelle/Monte Carlo of some vintage, or out of a big car (Impala, Caprice, wagon) because it is set up for a four link and coil springs.
Old 12-07-2009, 11:32 PM   #5
FED 387
Liked 333 Times in 180 Posts
Thumbs up Re: 12 bolt need help with I.D.
Housing widths --------backing plate to backing plate
64-67 Chevelle ---61 inches
68-72 Chevelle/Monte Carlo----62 inches
65-70 Big Car----62.4 inches
Comp 387
Old 12-07-2009, 11:49 PM   #6
FED 387
upon further review it is probably out of a early model year 1972 el camino/monte carlo/chevelle
KD ---is the gear ratio 2:73
C------is the assembly plant--- Buffalo
251---is the assembly day of the year---September 8, 1971
Comp 387
Old 12-08-2009, 05:27 AM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Comp 387
that looks more like the wheel mounting surface (flange to flange) measurements
try not to end up with a truck 12 bolt...
Old 12-10-2009, 09:11 PM   #8
stock eliminator
I measured the housing flanges outside to outside and it measures 55 1/4 "
Old 12-10-2009, 09:26 PM   #9
FED 387
My source tells me
64-67 is 56 1/2 flange to flange and 60 1/2 outside of brake drum to outside of brake drum
68-72 measurements are/is 58 1/2 and 62 1/2
68 was the transitional year so some early 68 vehicles might have leftover 67 housings
anyway kdc info is still correct--Comp 387
Old 12-12-2009, 08:31 AM   #10
stock eliminator
i measured the welded on flanges that the brake plate bolts too that are on the axle tubes.
i guarantee it's NOT a truck rear.
