ow yes 1.76 will last even longer sens u running a small block 383 how much motor u got? I ran 1.76 with 406 for yrs low 10s and never broke in 3300 pound car tried 1.96 gear set and car did not like it to much first gear for the power
#2 | |
![]() Last edited by L79racer; 12-12-2009 at 01:58 PM. |
lost on 60 and et cant remember how much been so long my car head 4.56 gears and 32-14.5w stiff side wall lunch at 5500 on brake shift at 6500 and 6800 at finsh line
Anybody else want to add what gear they run and et?
I ran a 355" sbc in a 2860# chevy II with a 1.76 glide 5.67 rear gear. Car went a best of 1.33 60' @ 9.86 and consistent 9.90's @132mph at 8200 rpm in cool weather. I put a 2.03 low gear and 5.43 rear gear. 60' times dropped to 1.30-1.29 and ran basically the same E.T. and mph at 7900 rpm. You will have more rpm drop at gear change with the lower gear ratio. Car has a 8" 5800 convertor and a 15" x 33" 105" roll out. I leave with the trans brake at 4200 rpm. The car was more consistent with the 2.03 low gear due to being able to transfer the weight better, and a whole lot more fun to drive! The 2.03 broke after about 350 runs. I put the good old reliable 1.76 back in for now! Hope this helps.
4878 SS/GA 66CHEVY II |
When you guys say the 1.76 gear set, is it a stock used gm gear set with the stock carrier and out put shaft? One option I'm thinking about is a 1.80 straight cut gear by transmission specialties in P.A. The whole tranny is $1600 PL-2500
Liked 5 Times in 3 Posts
I would go with the 1.98.... now then in a "stocker" we picked up .15 going from a 1.82 to a 2.08!
