Old 12-20-2009, 12:24 PM   #1
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: The just because I can category....
I used F as an arbitrary example, trying not to tip my hand, perhaps that was a bad choice, because I see where your confusion is, but yes sort of.... what I am saying is actually I can build a W car that can run well into the 14's, I had one in the low 15s with timing and some other "things" none involved even cracking the motor, with a long duration cam and coatings... Its possibly and potentially faster, I could see the combo breaking the high 13's legally....100% legally, if it did break into the 13's thats where Im talking about 3 seconds.
Originally Posted by 442OLDS View Post
I'm not sure that I follow this thead completely,but you are saying that you could build an F/S car that could run well into the eight second zone?
For example,the new F/SA index is 11.85.An 8.85 would be three seconds under.Is that correct?
Chris "drooze" Wertman is offline   Reply With Quote
Old 12-20-2009, 12:35 PM   #2
Liked 5,114 Times in 1,948 Posts
You're all over the map here. First it's a FWD, 4 cyl, then it's RWD. 15 seconds is only about 1 second under the slowest RWD class index. The first second comes easiest ,by the way.
I was going to treat this like Billy does,but then I remembered what it was like to be snowed in on a weekend . Enough for now.
Old 12-20-2009, 01:38 PM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: The just because I can category....
Mark......He, just another young BS'er. He dosent have a clue until he gets out there.
