Old 12-23-2009, 08:43 PM   #12
Pat Cook
Default Re: AHRA classes
Yep, ran a Formula4 H/S 62 six cylinder Falcon in 1971 at Beeline Dragway. Had a 500 Holley two barrel, any flat tappet cam, any compression ratio, (which was mill the head .250) Clifford research header, dagenham four speed that Hurst actual made a competition shifter for, clutch plate was rebuilt by Arizona brake and clutch, which amounted too replacing the springs with valve springs from a hipo 289 and used a clutch disc from a fork lift. Car would make around three passes and then break something in the trans. Might have been the hold it on the floor and side step the clutch launch????
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
