#1 | |
I dono Jim..we can use your car as a testbed.......Im working on the formulation of a phase change top cylinder lubricant that can be sumliminated into the fuel air stream thereby depositing a hyperviscous material that absorbs massive amount of heat during it phase change thereby removing it in much the same way a ceramic piston coating reflects it this will remove it , it also increases charge density so more "bang" action.... it semi soluable so NHRA tech cant consider it a "coating" and it has a short cylinder life because of the sodium composition, its soft, so it will only work for the duration of the sublimination cycle.......Maybe 5 or 6 piston strokes....
If my thermodynaics are accurate (and I think they are) well...well have to be careful not to lauch the test vehicle into a low earth orbit.... ![]() The trick is coming up with something that does not leave a corrosive or abrasive residue after its decomp point.......the hunt goes on.. Hey Ive got nothing better to do in a Hospital room on a Sunday evening.... Cant find anywhere in the "Rulez" its dissallowed...hence its legal right ![]() AND to all the rest Im only half serious....the low earth orbit thing is bunk....really in an ideal world itd be good for 1/2 sec..... ![]() Quote:
Liked 584 Times in 94 Posts
Jesus Drooze: I thought the headache came in the morning ............
#8, If you attend the Sports at No Problem this year after you have hit HP 3 times as planned do not go on the swamp tour with Jeff LOL !!!!!!!!!!!
Doug Frazier D/SA 2038 |
