#1 | |
Liked 14 Times in 11 Posts
coil where it is on the right inner fender with a short coil wire. Instead of inside under the dash with the MDS box?
Phil Saran Parker, Colorado |
Place the coil under the dash as close to the distributor as possible to keep the length of the coil wire as short as possible. I use the MSD bulk head connector that utilizes 2 short wires. Not sure if there is an advantage to having 1 wire versus 2. That would be a good question for the MSD Tech Dept. There are at least two advantages to having the coil out of the engine compartment. 1) The decrease in heat will make the coil last longer and 2) Coil will perform better over time due to less internal degredation caused by heat.
Nelson Kowal Stock 345 |
