Old 01-15-2010, 10:56 PM   #1
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Glaring omissions from classification guides
What about the older stuff like the TC , will Chrysler still submit that ? They made the one with the Cosworth head and its a screamer. Also on the "Cheap" you can pick one up under 5k if you find it right.
And what about in the case of divisions that are no longer operating like Oldsmobile ?
Or divisions that havent even submitted something in 18 years+ (Caddy)
It seems suprising, there are some good modern combos that just arent there.
And with the cost of the old iton and the scarcity it would seem that people would be trying to grab some of the hot new iron.
Like Olds...why the hell is only the Alero listed......thats just odd...
What happens if the division is "POOF" ?
Cheers
Originally Posted by Ed Fernandez View Post
I think if you want to run a certain combo not listed you need to make a request to the manufacturer to provide NHRA with specs.NHRA can't be expected to list every combo out there,especially the odd ball ones.
Chris "drooze" Wertman is offline   Reply With Quote
Old 01-16-2010, 08:59 AM   #2
Evan Smith
Liked 115 Times in 5 Posts
Ed is right. The manufacturer fills out a form with the vehicle data and submits it to NHRA. Then NHRA approves (or not) and inserts it into the guide. However, if no one at the manufacturer is interested in drag racing, then there is no one to send in the data. In this case, it generally takes a racer contacting the manufacturer to get the ball moving.
As for defunct manufacturers, I guess you'd first have to find someone at the parent company to access the data, then I guess NHRA would have to decide what to do.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
