Old 01-16-2010, 03:58 PM   #9
magnumv8
Default Re: One or two batteries for Stock Elim.
drooze.....just remember that the secondary battery still has to be able to START the car as well as the primary battery (NHRA regs)....and as a side note... I personally won't use "deep cycle" marine type batteries anymore because they do not like to provide FULL cranking power on a start up...they are designed to allow as much power as possible while going to a full discharge of voltage.....I burned up 2 optima yellow tops before I found this out and now will avoid the deep cycle batteries for that reason....
D L Rambo....
magnumv8 is offline   Reply With Quote
