Old 01-17-2010, 08:58 PM   #1
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Aluminum trailers
ATC, is the Best Trailer for the money .... Goldrush & T + E are much
more expensive ... Check them out and see, you will buy an ATC in the
end .... Featherlite, also makes a nice Trailer for the money... Good luck, in your search and compare apples to apples.... LOL
Dave Ribeiro 1033 STK
Old 01-18-2010, 09:29 AM   #2
James Perrone
Liked 1,843 Times in 430 Posts
Default Re: Aluminum trailers
Pace make an aluminum trailer..
I own a 24 ft it a good trailer 5000lb axle
Nice and light reg lb 3300lbs
Optima starts the build and Pace finishes it
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 01-19-2010, 12:44 PM   #3
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
Originally Posted by Steve Polhill View Post
Ron
If you are thinking that a lighter trailer = better mileage, It would take you MANY years to make up the difference in the cost of the trailer with fuel savings.
Think of it this way. If your Motorhome got 10 MPG Now with a regular trailer it would take 50 Gal of fuel to go 500 Miles. 50 Gallons x $2.70 per gallon = $135 each way. Now say your new Alum trailer gets you another MPG to 11 MPG, the same trip would take 45.5 gallons of fuel . So 45.5 Gallons x $2.70 = $122.85 each way so you would save $12.15, or $24.30 round trip. That means if you bought a $15,000 Alum trailer, over say the $9000 Steel trailer that I bought, You would have to go 246,914 miles to make up the difference is price. And knowing how much you travel in a year I'd say roughly 3000 miles, it would take you over 82 years to cover that much.
Just to put things in perspective.
If you are going to put things in perspective...do it all the way.
Towing that steel piece of sh!t behind you puts additional wear and tear on your truck/motorhome's engine/tires/frame/brakes etc. It will also go through trailer tires faster... Put a price on that..
Think resale. In 10 years that 9000 steal trailer will be worth 3000...if it hasnt fallen apart yet. The 15000 aluminum one will still pull in 10k.
Goldrush and T&E are the only way to fly.
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is online now   Reply With Quote
Old 01-19-2010, 02:28 PM   #4
Greg Turk
Greg Turk's Avatar
Liked 19 Times in 4 Posts
Thank you Steve , its much clearer now!!
TURKMAN
4002 Stock, 4002 Super Stock
Greg Turk is offline   Reply With Quote
Old 01-19-2010, 03:12 PM   #5
Greg Turk
Greg Turk's Avatar
Steve.....Why you gotto be like that????
Thankx for the extra eyes...my search ended a couple of weeks ago
I'll send you a PM with pix
later....
Turkman
TURKMAN
Old 01-19-2010, 06:57 PM   #6
rseibenick
Liked 20 Times in 7 Posts
The main reason I am looking for lighter Aluminum trailer , is my RV can not haul a lot of weight. It is a 94 Allergo Bay 35 ft. DP with a 5.9 Cummins 190 HP Turbocharged and intercooled engine with a 4 speed Allison transmission. Book says not to tow over 6000 lbs. I am going to redo the hitch and make it stronger, but with a lighter trailer would hopefully not put me over the total GVCW limit of my RV. I will usually have a 2300 to 2500 car in the trailer. Thanks for all of the ideas and infomation. Ron.
rseibenick is offline   Reply With Quote
Old 01-19-2010, 09:08 PM   #7
rseibenick
Been looking at the ATC , Featherlite and Gold rush trailers. I also ran across the Nash and Rance aluminum trailers. Anyone have any info on these brands.
Old 01-21-2010, 12:48 AM   #8
Jim Carter
Liked 19 Times in 3 Posts
Thumbs up Re: Aluminum trailers
Your concern over trailer weight, while towing with an RV is well founded and THE second best reason to go aluminum. You can also pick up a used (oops), pre-owned aluminum trailer for close to the same price of a "new" steel unit. The first best reason is enhanced RESALE value. The depreciation on aluminum trailer value will typically level off after it is a few years old and just flat line.
BTW:
Talk to Johnny D at DRC when you are ready to beef up that hitch. He makes a nice "Do It Yourself" hitch kit that is well designed and engineered for RV's.
Dave Ficacci knows what he is talking about from his own personal experience.
Keep that open trailer until you can get the aluminum unit.
I bought a used Motorsports trailer and am very happy with it. They are no longer in business but they are serviced by Goldrush. Pre-owned units are out there.
Just my two cents.
JimmieC
Jim Carter is offline   Reply With Quote
Old 01-21-2010, 05:20 PM   #9
JJ3159
JJ3159's Avatar
i have a used 28ft atc for 9900 gilloglyresale.com there is pics of the trailer.
jj h/r 1399 s/r 1399 s/g 1399
JJ3159 is offline   Reply With Quote
Old 01-21-2010, 08:55 AM   #10
Lightbulb Re: Aluminum trailers
Dave -- I agree -- whatever you are towing with will be used much harder towing a steel trailer and the steel unit will be valued much less when sold 10 years later but its been my experience that after 10 years a aluminum unit such as a Goldrush / Motorsport / Featherlite etc. will be valued at what it sold for new or very close .
