Liked 6 Times in 2 Posts
Anybody have a good way to remove Decals from a race car ! Any help will be appreciated !,,,,,,,,,John
John Lang 365 STK, SS |
Adhesive backed? A heat gun, or elec hairdryer. Should peel right off. Then use "Goo-Gone" to remove any remaining residue. Goo-Gone is a citrus-based household solvent that will not affect automotive finishes. WJ
Oh yeah, heat them up with a hair dryer, slowly peal them off, then use WD40 or CRC and a clean towel to remove the goo left behind. (old school). Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 535 Times in 110 Posts
Hair dryer works great for me too. Be sure car has been sitting in a warm garage and sheet metal is room temperature, helps prevent pulling decals along with the paint.
Jim Kaekel 3836 STK |
Liked 883 Times in 237 Posts
Heat gun or CRC work good........Found a product called Goo Gone that works real good on some of the more stubborn ones,usually the laminated type ,it's citrus based,and dosnt hurt the paint. .......Tom..........OOPS,I did'nt see your post WJ.
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 01-26-2010 at 05:26 PM. Reason: OOPS |
How about removal of the old style decals? The ones that we used to put into a pan of lukewarm water and slide them off the paper backing, then apply them and squeeqe out the water bubbles....I know on glass it's a simple deal w/razor blade for removal, but what about removal of this style decal off lower (painted surface) body panels, etc.??? Any "senior racer" tricks for these???
In the autobody industry we use a rotary rubber eraser tool for large decals, if used carefully no paint lifting and a just a little polish on the paint for the rubber residue
Dion Hildebrandt 6009 STK H/SA |
Thanks All,,,,,,,,,,Will try your idea's, and I'll let you know !..........John
#9 | |
Any autobody shop should have those, some people call them plastic razor blades. Use a heat gun to get the glue good and pliable, than use the 'razor blade' to scrape the sticker off if necessary. Goo Gone like mentioned above is good for the residue. Easiest possible way to do the job.
2002 Division 6 High School Champion 2007 Division 6 Pro Champion 2007 Division 6 National Open Series Stock/Super Stock Champion |
