Old 02-15-2010, 01:47 PM   #3
MOVEMAN
Liked 11 Times in 2 Posts
Question Re: New Tech Rules
"Parachutes must have their own independent mounting with sleeved 3/8 1/2-inch
minimum steel bolts or steel pins required for all applications. Shroud line(s) mounting
brackets must be constructed of minimum .090-inch steel. Material around the holes for
the bolts/pins must be equal to or greater than the bolt/pin size."
On the 2010 rule amendments page#22 the 1/2 has a line through it as if the are now allowing a 3/8 bolt! I'm more confused now since Chuck says they got him at Bradenton for what ? Having to big of a bolt?
There is also a line through the complete last sentence in the above quote, but nothing to replace the wording?
Rich
Time To Move Racing
"Creating Customers For Life"
MOVEMAN is offline   Reply With Quote
