Old 02-20-2010, 05:36 PM   #1
David Ley
David Ley's Avatar
Send a message via AIM to David Ley
Default Re: NHRA Stock/Super Stock Classification
All the information you need is in the Classification Guide and the Engine Blueprint lists. If you look at the top of the 68 Ford Class Guide ( GT Specs) it shows the different HP ratings for the different heads. When you go to the specific car in the Class Guide ( 68Mustang ) it shows the replacement heads. In your case Canfield or AFR. Now if you are really serious about this combo you can claim it as a 68 Mercury 302 and you get to use a Holley carb.
Dave Ley
NHRA TECH
David Ley is offline   Reply With Quote
Old 02-20-2010, 10:27 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
I typed the wrong info earlier. The 230 HP 4 bbl motor is NHRA-rated at 220 with OEM heads and 230 with replacement head. I incorrectly wrote 200 earlier with OEM heads.
Old 02-21-2010, 11:29 AM   #3
Bill Harris
Liked 26 Times in 13 Posts
Bruno, the C8OE-J heads are the 2BBL heads and have a larger combustion chamber than the 4BBL heads. The 4BBL engine was 10:1 while the 2BBL was 9:1 which is why the chambers are larger. So, no, you can't use them on the 302/230 engine in S/S. The right heads are either C7OE-C or C8OE-F.
There are two aftermarket heads approved for the engine. One is a AFR #1299/165 and the other is an Canfield #18350. The S/S HP using the aftermarket heads is 230 while it it 220 if using the Ford heads.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 02-21-2010, 07:27 PM   #4
Jeff Lee
Jeff Lee's Avatar
I'm with Terry and I've looked at this as a GT / SS option for a Maverick. Go with the 1968 Mercury 302. Class break down is the same as the '68 Ford 302 4bbl
Jeff Lee 7494 D/S '70 AMX
Old 12-01-2010, 10:03 PM   #5
Wisman Racing
Wisman Racing's Avatar
Liked 4 Times in 2 Posts
I am putting my '69 Camaro into super stock next year. I just need to know if IHRA's horsepower factor is the same as nhra's, and if I were to goto super stock production how do i find a combination to use?
Wisman Racing is offline   Reply With Quote
Old 12-01-2010, 11:27 PM   #6
Mike Carr
Mike Carr's Avatar
IHRA Super Stock Production is pounds per cubic inch. Weight of the car with driver, divided by the cubic inch of the engine = the class you will run. If it fits into, say, SS/PAA-1 (7 pound class) with a 427, you would weigh 2,989 pounds.
In horsepower to weight categories, IHRA generally mirrors the NHRA ratings, but not always. As an example, the 1990's LT-1 in a Camaro/Firebird for SS/IA, it's rated 279 in NHRA and still at 275 in IHRA.
All the IHRA info, including people to contact regarding a question, can be found here.
http://www.ihra.com/competition/index.php
Old 12-02-2010, 09:18 PM   #7
Ryck Campbell
Ryck Campbell's Avatar
Liked 46 Times in 10 Posts
Bruno,
Actually there is no such thing as a "natural" class in NHRA SS/GT. Using the 12.98 weight break, the car's shipping weight is 2726. From there you can subtract a maximum of 250 pounds or add a maximum of 250 pounds to calculate what classes the car can fall in. With the maximum removal of 250 pounds the car won't make the top of GT/F(A) with the 230 hp engine but the car could:
run heavy in F @ 2670
G @ 2700
H @ 2815
I @ 2930
J @ 3045
using the 220 HP engine in would be:
heavy in G @ 2670
H @ 2700
I @ 2810
J @ 2920
K @ 3030
L @ 3140
This is using the data available as of today, 12/2/2010. Hope this clears things up a little.
Ryck Campbell
NHRA Technical Specialist
Ryck Campbell is offline   Reply With Quote
Old 12-02-2010, 11:37 PM   #8
1299
Liked 54 Times in 12 Posts
so if t have a 83 grand prix (shiping w-3300) with a 327 nhra rated at 299
i can add 250 to it?
so 3550/299=11.87 which is gt/h or remove 250 and get 3050/299=gt/e
so i can run from e-h????
1299 is offline   Reply With Quote
