Old 02-25-2010, 11:09 PM   #18
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Manual Trans Help
I am very curious about this thread, I have "considered" also running the DP as a stick car.
I likes gears.....and Im good at shifts....(better if I can do it with my foot but...)
I am seeing everyone say go aftermarket, pretty much across the board.
I have a new T56 Viper tranny that came with the DP car (ours didnt come with a "core" as many others did, but a current year new tranny)
So.....
The ratios are
2.66
1.78
1.30
1.00
0.74
0.50
2.90
I would obviously never get past 4th (gated plate to lock them out ?)
Is there anything "wrong" about running this trans ?
I know they can handle the power if built right, no problems.
What other things might be "run into" using this combo ?
The other ratios readily available are
2.97
2.07
1.43
1.00
Just thinking ....
I like the idea, but Im not shelling out 5k+ on our next auto PLUS a gearbox, IF I could use th viper tranny I would consider it, otherwise its going in my 72 Chally.....
Cheers
Chris
^^^^ That's basically it. It's just a hard combo to make leave consistently.
We ran .88's with the stick ,but I suppose, with the high dollar lifters and higher seat pressure , you could run it through okay with 5.13's . That might help with overall gear ratio lower. I don't see where a lightweight double or triple disc setup would work . It seems to need some flywheel weight to launch within the rpm range.
The automatic cars work very well with a 4.56 gear, so you see that all that extra gear required for a stick is not a good situation.
Bottom line ,as I said; Too much weight, not enough rpms for a stick.
Build a 67-8 car if you have to have a stick shift Pontiac.
Thanks for reading and remembering those articles.
Mark
Chris "drooze" Wertman is offline   Reply With Quote
