Old 02-28-2010, 05:18 PM   #1
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Blog of the building of a Challenger Drag Pak
Originally Posted by hemidup View Post
To play it safe, get yourself some 6.1 coil packs, 6.1 coil pack plug ends and 6.1 valve covers. Cut the 5.7 coil pack plug ends off and wire in the 6.1's and you'll be good to go.
Gotcha, only problem is the other 5.7's I have have 6.1 packs Dono why but they do, later stuff I think, same part numbers on em....3 pin connectors, I hope like hell they are the same Im running a mix an match on the DP
Im only going to run a few pounds, plus Im running E-85 in it.....I want some really loud fans
That and the 6 speed should make for a fun ride.....just gotta decided on a color to paint it, I was thinking Panter Pink with a "Mod Top".....takes a man with stones to drive a pink car...
But I have a complete new black interior so, the mod tops look best with white...
I was thinking of using the material that is like mod top but more paisley from a 70 Imperial for the roof, be different
Chris "drooze" Wertman is offline   Reply With Quote
Old 03-01-2010, 01:50 PM   #2
Harry 6674
I've been using the Megasquirt stuff in a 53 Stude/500 Cad bracket car for about four years. Easy to build and works great. The Megasquirt stuff is cheap, the rest of the required stuff to convert to efi,not so much.
Harry 6674 is offline   Reply With Quote
Old 03-01-2010, 05:27 PM   #3
Jeff Stout
Liked 706 Times in 283 Posts
With dual plugs and coil packs do the 6.1 do they fire at the same time or different times to have a longer spark timing? Also what after market system are being used to work on ignition side of electrical system?
Old 03-01-2010, 07:52 PM   #4
Jeff Teuton
Liked 325 Times in 50 Posts
I think mostly the FAST system. We have two running on the 5.9 magnum which is one plug, but we have the pieces to fire the hemi's also. I think they fire 2 plugs together. If you haven't run one before and are like us that eat the top of trees, you just are really amazed how adjustable they are. In the dyno room, we only go in to add fuel. The rest is on the laptop next to the dyno console.
Jeff Teuton 4022 STK
Old 03-02-2010, 10:58 AM   #5
Harry 6674
Megasquirt also has the kits to handle the ignition part of the system.
Old 03-02-2010, 11:58 AM   #6
Dwell you set in the ECU, and yes the 6.1 coils fire both same time for flame travel. They fire neg/pos on the polarity
Old 03-02-2010, 03:16 PM   #7
For those who car....
Video and pics of the car being wrapped, dynod and tracked.
Courtesy of one of our (and main/title) sponsor
Jerry Hoffmann at DiyAutoTune.com
Enjoy....
Old 03-02-2010, 03:35 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
The time lapse of the wrap was pretty entertaining....nice job whoever made it.......
The run.....not so much.....I get about 13 seconds from weak launch to where you let off.....
Better work on that......!!
Rich Biebel
S/C 1479
Stock 147R
Old 03-02-2010, 03:52 PM   #9
The run and launch was intentional it was the first time the car has tracked anywhere, (intentional except the rollover on staging, I was paying attention to electronics) and well....
It crept off the brakes , and I wanted to see at what pressure and rpm, but at that point I got in it, I got the data I needed,.
Shift points were at 6500 adn 6800, 11 secs is more like it btw....let off around 1000 was only going to run a short 1/8th but well it felt so good I kept in it....
My daily driver is a 13(13.2-5 with street tune) sec car so I can say I know what 13 seconds feels like all day long....lol.
2 different things shaking one out and racing it, at least in my book, that was a very aggressive shakeout run for me (for a 1st pass on a car) about 5 or 6 more and shell be ready for a full hard pass.
Back on the road to Atl for Thursday T&T then div.
Assuming we dont break anything on Thrusday
Yall are gonna REALLY love my typing now I got a new laptop keys are odd....like everything around here.
GatorWraps did the wrap, and got some real estate for doing it. They did wraps, DiyAutoTune covered the rest of the wrap cost as well as much (all) our electronics and wiring costs , and tuning, and on and on.
Jerry did the Video , I thought it was pretty cool. So I thought I would post a link.
Cheers all...
Id never seen a wrap done before and always wondered how it wsa done.
