Old 03-01-2010, 01:19 AM   #1
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Advantage of 2 Step on Stocker???
I'm pretty sure this won't get mentioned unless I do it, but on an automatic turbo car, a 2 step is a necessity.
As you stall up the converter, the boost comes in, so then the stall speed increases, then more boost and so on ,until the brakes no longer hold . The 2 step caps off that process at a predetermined point, in my case ,about 3800 rpm.
Very good to know....interesting and makes sense seems like one of those things youd never know unless youve been there, building a twin turbo 72, I was going with a 6 speed but if I go auto Ill know, thanks Mark.
Chris "drooze" Wertman is offline   Reply With Quote
