Old 03-17-2010, 10:49 AM   #1
Bruno 3776
Bruno 3776's Avatar
Default Re: Another Question About 2-Steps
I my dad's car, we drilled the brake pedal on the lower right hand side and added the button to the pedal. His car has a large brake pedal so it made it easy to do however you just have to be careful when you depress the pedal at the top end not to hit the button.
Ronnie Dozier
Bruno 3776 is offline   Reply With Quote
Old 03-17-2010, 11:18 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Talking Re: Another Question About 2-Steps
I have not put one on my car yet. But there is two different ways to mount the switch. Either on the brake pedal like stated above or a pressure switch T-ed into the front brake line. Either way I would put a switch on the shifter that is in series with the switch on the pedal, so that the button for the two step only works in low gear. That way when you are slowing down at the line or the turn off you do not activate the two step again. Mack by the way what track is your home track? SGMP?
Robert
Robert Simpson is offline   Reply With Quote
Old 03-17-2010, 01:24 PM   #3
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Robert
Robert, I race there, Gainesville and Orlando.... Don't really call any of them my "home track". But if I had to name one it would be SGMP... Just because I have raced there more.....
I understand about the switch on the shifter for only 1st gear but what if you have the auto shift valve body and you start with your shifter in 3rd and just the valve body does the shifting??
Mack Reeves
2377 STOCK & SUPER STOCK
Old 03-17-2010, 11:19 AM   #4
Jared Jordan
Liked 539 Times in 120 Posts
Send a message via AIM to Jared Jordan
Some guys use a brake pressure activated switch. One SS car I know of had a 1000 psi switch. Didn't have to worry about activating it at the finish line that way. You'd never be on the brakes that hard and if you were, the 2 step activating would be the least of your problems.
I've also seen a couple guys use a microswitch mounted on the shifter that disables the 2-step when the 1-2 shift is made.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 03-17-2010, 01:27 PM   #5
Mack Reeves
I like the pressure switch idea and you are right if you are on the brakes that hard at the top end you need a 2 step kicking in!!!!
Mack Reeves
Old 03-17-2010, 02:07 PM   #6
GTX JOHN
We do not use them but we have seen some stock guys just put a switch on two step and activate it by hand in high gear. That
would work with stock shifter. Just do not forget to turn it off. Most of guys I have seen use ford brake light switch. Guessing more like 10-20 psi. John Irving
