Old 03-19-2010, 01:17 PM   #9
mannymen
Liked 13 Times in 7 Posts
Default Re: 69 Camaro Cowl Induction Flapper Valve/Upholstery?
Any help/pics from other Camaro owners? In need of more help.
If I just have the solenoid connected to the flapper valve will there be too much vacuum that it will actually close the flapper valve down track, which will cause a bog? Kind of like having your holley carb choke plate close on you down track if it isn't fixed open.
The reason I'm asking for help is that my car is kept more than 800 miles away and it's not like I can go into the garage and check things out for fitment.
Bueller! Bueller! Bueller!
N/A
mannymen is offline   Reply With Quote
