Old 03-22-2010, 11:47 PM   #1
04BlackSilverado
04BlackSilverado's Avatar
Default Re: Newbie wants to race... But what class??
Originally Posted by Mike Carr View Post
If you wanted to run Stock, there are truck classes for factory trucks. Crate Motor Stock is also an option, using one of several IHRA-approved Crate motors. Both Stock Truck and Crate Motor Stock are for 1/2 ton or smaller trucks.
From the IHRA website:
http://www.ihra.com/competition/pistons.php Accepted Replacement Pistons
http://www.ihra.com/downloads/pdf/co...ateengines.pdf
I looked at the Crate class, and it looks like the only LS motor allowed is the LS1, which is smaller (ci wise), more expensive, and an aluminum block (again more expensive). The approved LS1 pistons are only for the smaller bore LS1 not the 4" bore LS2 or LQ9 Pistons.
I'll look more at the truck class...
2004 RCSB Silverado 6.0L 2WD
04BlackSilverado is offline   Reply With Quote
Old 03-22-2010, 11:53 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Here are some people to contact, to see if an '04 Silverado is eligible for Stock. If not, most all IHRA Divisional Pro-Am races offer Box and No-Box ET bracket classes.
http://www.ihra.com/competition/index.php#contact
Old 03-22-2010, 11:56 PM   #3
04BlackSilverado
I know bracket racing, but what is "box" and "no-Box"?
Thanks for your time, Mike
I'll send them an e-mail
Old 03-23-2010, 12:02 AM   #4
Mike Carr
Mike Carr's Avatar
Box allows Delay Boxes. No-Box does not allow delay boxes. Different classes go by different names at different tracks. ET 1, Super Pro, Electronics, Box are usually the same. Pro, No-Box, ET 2, Modified same thing. Most tracks (but not all IHRA Pro-Ams) offer Street ET also. Most classes have a maximum ET that you can dial-in. Box might be no slower than 11.99, No-Box might be no slower than, say, 13.99 or 14.99. Street ET is usually no ET limit, though some I have seen are now slower than 17.49, or 19.99.
Old 03-23-2010, 12:07 AM   #5
04BlackSilverado
Oh, I got you.
I raced a Bracket at a Truck Nationals event and it was a delay box. Not a fan, I lost due to a major padding of time in the other lane and some light braking. I raced all out... I still had fun.
Wow 17.49... The truck with the 5.3L (100% Stock) got a best of 15.2 in the 1/4 @93mph
Old 03-23-2010, 12:12 AM   #6
Mike Carr
Mike Carr's Avatar
If you're running 15's, you will be fine in Street, and maybe Pro at some races. Rules, as far as maximum/minimum allowable dial-in ET, safety, what electronic aids (Delay Box, air/electric shift, two-step, transbrake, etc) may/may not be allowed by class vary by track. Best bet before going to a race somewhere is to call or check the track website for what classes are offered, rules, etc. Also, FYI, if you come here tomorrow and don't see this thread, chances are it was moved to the "Stock and Super Stock Tech" Forum on here.
Old 03-23-2010, 01:20 PM   #7
treessavoy
Liked 4 Times in 4 Posts
Beef up the suspension on the truck and use it as a tow vehicle and buy a low dollar lower class car....and there's plenty.....get a trailer and go racing!
JimR
Jim Rountree
Old 03-23-2010, 03:26 PM   #8
s10stocker
s10stocker's Avatar
Oh, I got you.
If I have the HP correct the LS1 CM is rated at 350. Now if you were to run I/CM the index would be a 12.10 and you would have to weigh no less then 3670lbs. 3670 - 170 / 350 = a weight brake of 10 which is I/CM. Do you think you can make a LS1 run a 12.10 or better while keeping your truck at 3670lbs(with driver) or higher and following all the rules of SE?
Hope this helps.
George Roussel Jr. 4262 1996 S10 n-o-p/sa
s10stocker is offline   Reply With Quote
Old 03-23-2010, 06:33 PM   #9
04BlackSilverado
Would this cover all LS Series V8's? Or only the LS1?
The LS7 is a 427 making 500hp
The LSX 454 is making 600+hp
But, My Motor is NOT the LS1 it is essentially a LQ9 rated @ 245hp for the 04 Year(Came in the Silverado SS)
Would I use this # Instead?
I would probably want to be into the J or K Class since I think I would run between a mid 12 to low 13. And my weight as it sits right now is 4600 with driver. Soo...
4000lbs (with major weight reduction) - 170lbs / 350 = 10.94 Which puts me in the J/CM Class.
I think I can do 12.5 - 12.99 and compete.
Not yet anyway.
No Problem keeping the truck above 3670#'s!!!
I'll have to go through the rules to see. I'll let you know.
