Old 03-27-2010, 12:45 PM   #1
Charley Downing
Liked 653 Times in 89 Posts
Default Re: Another bogus hp rating.
Bruce the non Super CJ makes way less then 800hp to the rear wheels. What is you point.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 03-27-2010, 12:57 PM   #2
Liked 1,953 Times in 439 Posts
It's interesting how people throw "torque" around.
HP=Torque x RPM / 5252
So HP is nothing other than a mathematical derivative of torque.
It's been a long time since I've seen a normally aspirated car in Stock Eliminator (especially when you get above L,M, or N) run less than about 5500 RPM stall, or leave at less than 5500 if it is a stick car.
So, 5500 RPM is above the point at which torque is a higher number than HP, as torque and HP will ALWAYS be equal at 5252 RPM, and torque will ALWAYS be greater than HP below 5252 RPM. That also means HP will ALWAYS be greater than torque above 5252 RPM.
In this modern era of efficient high stall converters that yield in excess of 2.0:1 torque multiplication at their flash stall speed, and trick clutches, when someone tells you that it is necessary to have "torque" when "moving a heavy Stock Eliminator car", remember that in order to make HP, you must have torque to begin with, since torque is the actual force, and HP is merely a mathematical derivative of the force called torque.
Two engines that have "X" HP at 6000 RPM have the same exact amount of torque at 6000 RPM, regardless of how many cubic inches they displace, what their bore/stroke ratio is, or what their rod/stroke ratio is.
Old 03-27-2010, 02:16 PM   #3
Bruce Noland
Liked 444 Times in 145 Posts
The point is you need to keep up with these threads if you want to brow beat folks. Read some of the old threads on the CJ's and you may learn something.
Bruce Noland 1788 STK
