Old 03-29-2010, 06:59 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,931 Times in 580 Posts
Default Re: Launch question/Going left
Thats your problem Ed. Repair the bolt holes by either the method that Wade suggested or the plate method like I used. Put your ladder bars side by side and make sure that you can slide a bolt through both heims on all 3 heims. I usually set my car up using some solid joints and some strut rods set to the same length as the ride height of the shocks. all of the bolts should slide in and out of the front and rear end brackets. The bars should have 2 degree down angle in the front in relation to the rocker panel. about the same on pinion angle. If everything is square and level you should not need any preload.
Good Luck!!
Mike Pearson 2485 SS
