Liked 557 Times in 217 Posts
I had a '96 GMC single rear wheel pickup.....Vortec 454. It had decent power and towed fine. I bought it new and it served me well untill last Sept. I towed a box trailer with various cars inside and also have a pickup camper I used. Mileage was about 10+ towing just the trailer....add the camper and it would get about 9.....
I sold it and bought a 2007 Duramax.......Wow what a difference!......No comparison.....power and mileage.....It tows my trailer like it's not even there....and that is not an exaggeration......Gets 12+ towing and back and forth to work......and better on the highway......I loved my old truck but my Duramax is way better....
it was 96 and up for the vortec ,it is a big diffrence ,in my 89 i had some k&n stuff and a tornado it helped
jj h/r 1399 s/r 1399 ![]() |
OK guys, I am stuck with this one for a while. Its not that bad, I dont do a lot of traveling with it, just want to help it out, not trade it just yet, but thanks anyway.
Tony Hall 3545 S/ST |
Tony,
You can make some minor mods such as better exhaust, K&N filter, etc. However, your truck is a speed density system which means it does not measure the airflow, it is calculated based on cu.in x rpm and then factored for load, air temp and barometer. The newer stuff has mass airflow so it is physically measuring the air coming in and can adapt for increases in airflow. What this means is that on a speed density system if you modify it too much, the calibration can't adjust because it is still assuming a pre-programmed amount of airflow. Example, early mustang GT's guys put the offroad H-pipe on them doing away with the cats and the cars would have idle issues, surging, dying etc. they ran good at WOT because it goes into open loop and max fuel delivery. In your case you need to maintain driveability. Hope this helps. See you at the track! Ron & Meridee 396V S/C
Ron Finney 396V S/C |
