Liked 695 Times in 206 Posts
NHRA has a new posting in tech about the wheelie bars.
Liked 20 Times in 14 Posts
lucas page
Liked 16 Times in 11 Posts
3/31/2010
The NHRA Technical department wants to remind Stock Eliminator competitors the use of additional bracing/tubing to frame, suspension or underbody is prohibited. The 2010 NHRA Rulebook, on page 9.8 reads in-part "Wheelie bar brackets may be welded to rear axle housing; bars and associated brackets must be stand alone items and not attached to any suspension or other components." The use of these wheelie bars are in violation of the NHRA Rulebook. Competitors with this style wheelie bar must bring their vehicle into full compliance with NHRA rules and regulations; on or before June 1st 2010
Bob Pagano A/SA |
Liked 20 Times in 12 Posts
What brought all this to light? I have seen these bars on Calverts cars for years? While I agree with the clairification. Did I miss something in the rule book about welded on sway bars? I have seen links and attachment points welded to the frame? I don't mean a coil spring car with a bolt on sway bar. I mean a leaf spring car with a sway bar control system on it? I don't know if that is legal or not? It has been several years since I have seen the photos of the cars in question.
Robert |
Liked 10,941 Times in 2,259 Posts
Did NHRA say anything about using dry ice in staging?
I would like to thank Ralph Popora for allowing me to look at some length at the AJE bars on his car. It was a lot of engineering in a very small space and nicely done.
Liked 70 Times in 22 Posts
Almost hesitate to enter into this for fear of being accused of b..ching but...Oh Well. Stock started allowing wheelie bars in 2002 I think. The wording has always been the same. Can not be attached to anything but the rear end housing. SS at the time had wheelie bars but it only stated that they could not be attached to the rear bumber of braces and it still reads that way today. But if you read the start of Super Stock it states that SS uses the same rules a Stock except where noted in the SS section. Nowhere in the SS section does it say that any part of the wheelie bar can be attached to anything so the rule from Stock applies to both Stock and Super Stock.
Just my read on the rules and as we know, opinions vary. |
#9 | |
Liked 129 Times in 59 Posts
I may be missing something, but the way the bars are designed they act as a lever with the fulcrum in the middle, not at the axle. If you push up on the wheel end it pushes DOWN on the end attached to the axle. On a normal set of bars the fulcrum is at the wheel end, lifting the axle.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
