#11 |
Liked 70 Times in 22 Posts
Almost hesitate to enter into this for fear of being accused of b..ching but...Oh Well. Stock started allowing wheelie bars in 2002 I think. The wording has always been the same. Can not be attached to anything but the rear end housing. SS at the time had wheelie bars but it only stated that they could not be attached to the rear bumber of braces and it still reads that way today. But if you read the start of Super Stock it states that SS uses the same rules a Stock except where noted in the SS section. Nowhere in the SS section does it say that any part of the wheelie bar can be attached to anything so the rule from Stock applies to both Stock and Super Stock.
Just my read on the rules and as we know, opinions vary. |
#12 |
Liked 10,943 Times in 2,259 Posts
I would like to thank Ralph Popora for allowing me to look at some length at the AJE bars on his car. It was a lot of engineering in a very small space and nicely done.
#13 |
Guest
Posts: n/a
This does not make any sense... What differance does it make if the bars pick up the diff and the upper body? Is it unsafe? No. Is it an advantage? No. Is it lighter? No. It is a differant approach for the same result. If anything it is a better approach to an outdated design. How about all the wheelie bars that are clearly too long for the car they are on. Very easy for a Camaro, Mustang and Mopar guy to see this...
Barry |
#14 | |
#15 |
Liked 129 Times in 59 Posts
I may be missing something, but the way the bars are designed they act as a lever with the fulcrum in the middle, not at the axle. If you push up on the wheel end it pushes DOWN on the end attached to the axle. On a normal set of bars the fulcrum is at the wheel end, lifting the axle.
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
#16 |
I think I started running them on my D/S AMX in 2005. I never even thought it could be a problem. D7 tech never said a word (and I know, past acceptance is not presedence).
Jeff Lee 7494 D/S '70 AMX |
#17 |
Liked 16 Times in 11 Posts
Here is my fix for the problem.
Weld a bar across the chassis with two pads on it, weld a strut at the fulcrum point with a pad on it. Gap the pads 1/8 inch. The bars will need to be attached solid to the rear instead of bolted. They should still work at the fulcrum point.
Bob Pagano A/SA |
#18 |
Liked 37 Times in 11 Posts
If any one needs a set, I have a set that I would sell.
Bill Kennedy 1671 SS |
#19 |
I remember when the AJE bars were first brought to market and reading the tech information and seeing the photos of them installed and the theory of their operation.....while they are similar in appearance and do give you "wheelie" control they are considered a traction device and NHRA did not allow them to be used in stock....they have never been legal.....and if you read the general regs 3.6 you will see that they aren't legal in superstock either....they must be "fixed" at the attachment point and cannot pivot.....
pretty much black and white to me...no grey area there..... D L Rambo..... |
#20 | |
Liked 328 Times in 80 Posts
Ernie Neal SS3400 |
