Old 04-04-2010, 01:06 PM   #1
FED 387
Liked 335 Times in 182 Posts
Question Any Ford dealer techs out there????
Any body work at a Ford dealership???? Need a someone to look up a TSB--technical service bulletin--- for me please--NEED THE TSB ###--- Vehicle is a -2000 F250 Super Duty with the 7.3 Powerstroke Diesel ONLY 97000 miles---supposedly a TSB refering to the bolt s either loosening or backing out completely on the turbocharger housing---when this happens the turbo fins get destroyed because the whole assemply is not containing the impeller correctly----- Need the number please and I'm also trying to find out if MAYBE Ford will cover this ---Seems to occur rather frequently not all that unheard of according to several repair shops I talked to--- Just trying to save $700-1000 dollars if I can get them to fix it under warranty----Thanx Comp 387
