Old 04-07-2010, 08:25 AM   #11
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: DP #24 Engine failure....
Originally Posted by LSP View Post
Drooze, are both the 5.7 and 6.1's aluminum blocks?, if so, are there iron blocks available for each?
Neither is alluminum block....both cast over the shelf same as street car.
5.7 has thicker walls can go .075 over usually no problem.
6.1 is thinner .030 max on a GOOD sonic check if youre lucky.
Our 5.7 is from an 06 Jeep Cherokee.....
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
