Old 04-12-2010, 03:38 PM   #3
67ss
Default Re: Front end setup
A 1/2" taller upper ball joint will just about cure all of what you are describing as well as give you a little more front end travel if you need it. That's what I did to my Chevelle. I have mono ball joints in mine like would be used in circle track cars, but we have also used the Howe Precision Ball joints in a .5" longer length in a buddies car and I liked them better. Check out scandc.com. They can build which ever joint you want instead of you having to buy the stock length joint as well as a longer stud and switch it out yourself.
And I know there are stockers out there that use this very method for curing what you are talking about as well as gaining front end travel.
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
