Old 04-12-2010, 08:22 PM   #1
Default Re: M200 breakage
We have never had a brace on a T 200 and have never cracked a bellhousing .
In fact , I always cut the ears off with a skillsaw and a carbide tip blade and de- burr the edges., Factory type engine mounts with a good, solid torque strap ,and a poly type mount.
I suspect your problem started with the driveshaft. Not sure why though.
On my Omega, (350 Buick stump puller), I shortened the original 2 and 3/4 ,thin wall shaft to accommodate the 12 bolt rear, and never had a problem with that either.
Old 04-12-2010, 08:51 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
We use a stock rear mount on our Malibu M200 and the same trans has over 1000 runs without any breakage. We have a Mark Williams driveshaft with about 1 degree pinion angle. Smooth as anything.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 04-12-2010, 11:04 PM   #3
Bill Edgeworth
Thinking about it more I would agree with what Bob and Mark both said. With the 60 foot you had the trans and drive shaft did not see a huge amount of torque. And I assume from what you said it did not shake or shudder on launch. It didn’t happen until the trans was in drive and starting to get up in RPM.
So probably something driveshaft related. The one thing I would check on the remnants of your transmission is the tail shaft bushing to make sure the yoke was not super sloppy in it. Could your drive shaft have been bent or dented? or overall length or yoke length a little short? Or touching drive shaft loop?
When Jim works on it you may want to also consider a roller bearing in the tail shaft.
Is that Peter Legg’s old car?
Are you going to have it back together for Bosie?
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 04-12-2010, 11:20 PM   #4
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Bill, it was smooth with no shake. The driveshaft was perfect length for sure, u-joints were good with fresh grease. The tailshaft looks ok, other than the seal has a slight bend when the yolk came flying out. The shaft looked good with no dents or any other signs of damage. Not touching the loop either. Could the shaft just have failed? seems rare to me that a shaft would twist and break like that.
It is Peter's old car, its not going to be back together for Boise now, all plans have changed, hoping to be ready for Mission.
also guys, I am using solid motor mounts along with the poly trans mount. so strap is not gonna do anything. Are the solid mounts not a good idea?
Grant,
I will e-mail you, thanks
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 04-12-2010, 11:07 PM   #5
Grant Eldridge
Grant Eldridge's Avatar
Dave,
I had several case failures with my TH-200, fortunately caught before catastrophe struck. I tried to buy a brace from McClay, but he only supports his own transmission customers, or at least did at that time. I built my own brace connecting the two "eyes" on the passenger side of the trans with 1/2" thick by about 1" wide aluminum. I tried to upload a photo but the file is too big. Email me at grant4060@yahoo.com if you'd like a few photos. I also bought an aluminum deep pan from Turbo-Action to act as a girdle and give more strength to the case. I run this behind a big block stocker, 3570 lbs. with best of 1.41 60' and since the changes have had no further troubles. The transmission is a reverse pattern unit built by Jim Mantle, who is the greatest guy to deal with, and his units have always performed perfectly. Ditto on using the stock rear mount, also would suggest the left front torque strap from earlier posts. Make sure there is enough spline depth in your driveshaft yolk so that it cannot bottom out when the car launches and the rear end pushes it ahead. Hope this helps,
Grant
Grant Eldridge is offline   Reply With Quote
Old 04-12-2010, 11:21 PM   #6
Grant Eldridge
Dave, I'll try to do these photos again....
Grant
P.S. No one will confuse these with the McClay brace, but so far so good...lol
Name:	TH 200 Brace 2 small.JPG
ID:	2856   Click image for larger version
Name:	TH 200 Brace small.JPG
Old 04-13-2010, 08:17 AM   #7
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
call frank lupo or shawn at dynamic he can get you a professionally made brace
jim powers is offline   Reply With Quote
Old 04-13-2010, 11:19 AM   #8
Todd Hoven
Guest
Posts: n/a
Leon Mirainian also builds a Tubular brace with heim joints. Great looking piece. I have had one on all of my metrics since I've been racing them. he also builds a great 200...
Old 04-13-2010, 11:25 AM   #9
Dave Jung
Dave Jung's Avatar
Todd, do you have a number for Leon?
thanks to all the guys who have replied. I really appreciate the help.
Dave
6535 stk
81 Malibu K/SA
