Old 04-14-2010, 10:28 AM   #1
cojo
Default Kaase turn key street/strip engine/ 750HP
For Sale:
Jon Kaase Engine Masters 468” BBF engine! This engine is being sold turn key off the dyno and makes 750HP on PUMP GAS!!!! This would make a killer street/strip engine! Below are a list of some of the parts which are the best money can buy! Again this engine is being sold “turn key” ready to run from carb to pan. I have documentation on the engine such as magazine articles as well as other write ups on the engine!
Block Ford Motorsports M-6010-A460
Heads Ford Motorsports M-6049-SCJ
Crankshaft Bryant Racing
Intake Manifold Edelbrock 2965
Carb Spacer HVH SS-4500-2
Valves Victory 1 – titanium TF/721, TF/716
Spring Cups Manley 42377
Head Gaskets Cometic C-5745
Rods Carrillo 17657
Oil Pan Moroso
A-N Lines/Fittings Earl’s
Rocker Arms Crane Cams 27771-16
Rocker Arm Studs Arp 235-7203
Stud Girdle Jomar 1143/1416
Valve Covers Fab Sheet Metal Ford 460
Main Bearings Clevite MS963P/ coated (calico)
Rod Bearing Clevite CB745H/ coated (calico)1
Cam Bearings LSM Eng. 60 MM Roller
Oil Pump Ford Motorsports M-6600-A460
Oil Filter Adapter Ford Motorsports M-6880-A50
Cylinder Sleeves Darton 4.650 Blank
Front Cover A.T Francis FC-429
Water Pump Weiand 8211 WIN
Oil Filter Systems 1 512561 BP
Spark Plugs Accel 762
Spark Plugs Wires MSD 31189
Distributor MSD 8380
Harmonic Balancer ATI 917520
Lifters Reed Cams 11115
Carburetor Barry Grant 97280-20
Wrist Pins Hoffman .990/2.930
Pistons Venolia 4881/127973/coated (calico)
Piston Rings Speed Pro/Total Seal BR18PF046
Camshaft Comp Cams FF7411-7413-108
Timing Chain Set Comp Cams 3122
Pushrods Comp Cams 7918/7755
Valve Springs LSM Eng 422
Roller Thrust plate Danny Bee 1520
ASKING $13,000 cash OBO
This engine was previously sold at Barrett-Jackson to a private collector for over $30K! This engine is fresh and has never been down the road or track!
Contact Joe @ 281 802 4283
cojo is offline   Reply With Quote
Search this Thread:
Advanced Search
