Old 04-18-2010, 02:33 PM   #1
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Default Front suspension advice
On those rare days when the air and track are really good, my car pulls the wheels higher and longer than normal. When it sets them back down, the front suspension compresses down too much. Not enough to hit the headers or pan, but more than I would like it to. It might be time for some dbl. adj. shocks,but I would like some advice.BB 69 Camaro,set up like a stocker- Moroso springs, Del-a lum (?) bushings,Calvert shocks,etc. Very heavy up front- iron heads, factory 4-core rad, all the factory stuff still in place. Thanks for any help.
Dana Fitzpatrick is offline   Reply With Quote
Old 04-18-2010, 03:29 PM   #2
72Malibu
72Malibu's Avatar
Default Re: Front suspension advice
I had the same problem with KONI shocks, now using www.santhuffshocks.com up front, nice and smooth once again. You might also check out AFCO, Varishock.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 04-19-2010, 07:39 AM   #3
Jim Kaekel
Liked 536 Times in 110 Posts
Dana- If you have a single adjustable shock now, you could try tightening them slightly on those "killer air" days to cut the wheelstand down a bit. I know AFCO has some double adjustable "Eliminator" shocks with "BNC" valving that eliminates bounce after a wheelstand.
Jim Kaekel 3836 STK
Old 04-23-2010, 10:24 AM   #4
jack arnew
Don't know if your stock or super stock, but if super stock install travel stops in upper control arms. Shut down some travel a little on those days when air or bite is very good.
jack arnew is offline   Reply With Quote
