Liked 10 Times in 10 Posts
M68,
I like your choices. The 70 A-Body cars should have been ready for a 440. My personal favorite/wish. My 69' 440 Cuda. But, with 11.5 pistons, Stage III Max-Wedge heads, an aluminum dual-plane high-rise with 850 Holley. And add in the .500 lift, 300 duartion solid-lifter Max-Wedge cam. Some lightening equipment, like aluminum water-pump housing, oil-pump, and trunk-mounted battery. Maybe if Chrysler could convince Alcoa to re-start casting aluminum heads, a nice set of aluminum Max-wedge heads. That should have gotten the car down to around 3225lbs. with 400HP (8.00 - 8.49 wt/hp) Paul |
X-Tech or M68,
A-Body question. 1967 Plymouth Barracuda Weight w/273 #2940 Weight w/383 #3182 1968 Plymouth barracuda Weight w/340 #3005 1969 Plymouth Barracuda weight w/440 #3405 Do these weights sound correct. my 69' 440 Cuda had a weight registration of #3310. Going by the weights, than a 67' 383/280HP would have been classed in D/S for 1967, and G/S for 1968. Is that correct.,,,Paul |
Liked 5 Times in 2 Posts
A 70-72 Duster with a
400, two 800 cfm 4barrels, 2.25X1.81 valves, a 700 lift cam, and a special T bolted block. second option that had special castings of the hemi head that would fit the wedge block. It would also be fitted with a scoop for clearance and design such that it weighed 2900 lbs with the driver. This engine would be kicking over 8500rpm easy and reeking havoc in a SS/B-D classes.
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
Just give me a 63 tempest stuffed with a indian adventures block with a long arm and some ram air v tunnel ports------you pick the trans and rear !!!!
Liked 2 Times in 1 Post
. . . . about 30 more 1967 L/88 Corvettes.
Ed, i read you there. Spoken like a true s/ss racer.
Liked 2 Times in 2 Posts
Boss 351 Maverick
455 Stage 1 Omega RamAirV '73 GTO SOHC Mustang, Maverick or Boss 429 '70 Falcon ZL-1 '69 Chevelle RamAir IV or V Pontiac Astre '70 Hemi Duster 440 Duster/Demon with Max-wedge top-end These are all easily buildable with pretty much factory parts. Randall AMC in Mesa,Az. built 401 Gremlins & even a few 401 Pacers! ![]() |
