Old 05-02-2010, 12:32 PM   #1
John Quinn
Default Re: miss. in eng
I once had a cracked coil that acted like that, when it cooled off at night it apparently took in moisture in the crack and when it warmed up it purged the moisture and ran fine.
The crack was so fine it was almost invisible. Changed the coil and the problem was solved.
John Quinn is offline   Reply With Quote
Old 05-04-2010, 11:52 AM   #2
Everett Vassar
Liked 2 Times in 2 Posts
Man it sure sounds like plugs.I know you changed them.Might try another set different brand. Also check for moisture/condensation inside the dist cap and the plug wire sockets.Do you keep the car outside?
Everett Vassar is offline   Reply With Quote
Old 05-04-2010, 09:16 PM   #3
1299
Liked 54 Times in 12 Posts
stay in enclosed trailer same as it did last year
1299 is offline   Reply With Quote
