Old 06-22-2007, 08:48 PM   #1
classof65
Default
It'll be coming out soon I'm sure. Gotta clean a bay out in the garage before I can do it. Just wish I had more time.
Just a strange thing altogether, car ran but had some "pop" issues under heavy load at the launch and then at the top of the gears - about 5000. Then we "fixed" that problem and by all accounts and tests, it should run, but wouldn't. Did the compression test - cool. Finished that up and decided to turn it over with the breaker bar to see if the distributor was in fact rotating - and on about the third pull it would pull no more. It has never lost oil pressure, but that doesn't mean alot I guess.
I feel like singing HI HO HI HO IT'S OFF TO WORK I GO.... But If I were to start that, I'd probably be stuffed in jail for disturbing the peace or impersonating a dwarf.
Peace, Rev.
classof65 is offline   Reply With Quote
