Old 05-11-2010, 08:06 AM   #1
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Default Re: Divisionals, records, and teardowns
"So if you run under the record but to not designate it as a record run, will you have to teardown?"
If NHRA wants to look at it, you will be taking it apart, record or not. The point here is always have gaskets and tools with you.
Don't forget you need the proper safety equipment, liscense, fuel check valve, etc.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
