Old 05-22-2010, 11:42 AM   #6
Liked 1,885 Times in 423 Posts
Default Re: bog
Bill, has it always done this, or is this a new problem?
You might try changing your two step RPM up or down in 200 RPM increments.
The problem you describe doesn't really sound like a loose stator shaft.
It sounds like the converter MAY be about 200 RPM or so too tight.
You might also try tightening the secondary air door an 1/8 turn.
There is a small baffle that attaches to the top of a QJet, on the two screws behind the choke horn. If you do not have one, you might want to get one and try it.
You might try a little more timing on the starting line.
