Old 06-06-2010, 09:49 AM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Class and engine for 65 Coronet
Go with the 383 Bob, I have a set of heads if you need them.
2009 V/SA Record Holder
Old 06-06-2010, 06:34 PM   #2
gonzo1066
Thanks Phill;
Just in the thinking stages, in a bit I will start thinking about how much money I dont have! This will be long term.
Good to get the help Guys.
gonzo1066 is offline   Reply With Quote
Old 06-08-2010, 10:54 PM   #3
treessavoy
Liked 4 Times in 4 Posts
The 426/365 has been rated to 300hp which would put you in G or H stock depending upon the weight of the car....this is a unknown combination whereas the 383 and 273 are proven combos.....the hemi is really expensive to build and run.
Good luck in your choice.
JimR
Jim Rountree
Old 06-09-2010, 01:43 AM   #4
Phillip marvetz
I believe the Hemi can only be ran in a post body, The Coronet 500 were hardtops.
Old 06-09-2010, 07:32 AM   #5
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thats is correct for the 65s unless he wants to build a MoPar crate hemi with a single 850 CFM carb for IHRAs crate motered class.
Old 06-09-2010, 11:24 AM   #6
Phillip marvetz
We don't have any IHRA tracks here in the northwest, Does AHRA have any crate motor classes? There are a couple tracks around that have switched to AHRA.
Old 06-09-2010, 12:09 PM   #7
X-TECH MAN
Banned
Not that I know of.
