Liked 138 Times in 51 Posts
2, maybe 3 times a year.
I also use the 4.2 lever and back off 2 turns on both adjustments. I'm pretty sure JW uses the red bands and/or clutches. Forgot the specific brand. Don't know what else he does or sets the pressure at, but mine don't have any "trick" parts in them. |
I was told this weekend to use Hydraulic/Transmission Fluid for Tractors in the P/G Trans to help with the Heat.
Anyone ever tried this and does it work.
Kevin Mclamb IHRA H/R & Top/Sportsman #9416 |
Liked 5 Times in 3 Posts
Hdy fluid/auto trans fluid are the same....My dad saw this "out in the field" as he drives a timber cutting machine for a living . he said some are thinner the the others but both work.
Liked 759 Times in 379 Posts
Allison TranSynd, been using it for 5 years switching from Type F to lower fluid temp and extend fluid change intervals.
Installed fresh at the start of every season, logging 200+ passes each season. Rossler Turbo400 and ATI converter Last edited by 1320racer; 06-26-2010 at 10:33 PM. |
Pennsoil Type F conventional trans fluid.
Nelson Kowal Stock 345 |
Kevin,
I've been told that by more than 1 tranny/convertor builder. I still stick with my synthetic though. I recently switched to the same stuff Myron uses AMSOIL trick shift. I will put around 400 runs on my glide this year and don't anticipate any issues. Chip |
Liked 361 Times in 104 Posts
I build race trans and you need to stick with any of the brand name synthetic fluids.
I prefer the Mobil 1 fluids. The synthetic fluids hold up better under the heat loads of racing in all areas and are better lubricants period. They are a little more expensive but worth it. My 2 Cents and experience from using and building the transmissions. Last edited by 63corvette; 06-27-2010 at 11:14 AM. |
