Liked 10 Times in 10 Posts
Lee,
Sorry, not to list it. Your Pop may have had the only one ever built. Not too many people rushing in to purchase 66' 427 Chevrolet Wagons. Only us at Dover knew it existed. I saw your Pop run those times, with the brake-lights on going through the traps. Remember, I was always at the end of the pits, near the Trophy Booth. What was it, C/S in 66', B/S in 67' and D/S in 68'?? Your Pop and Joe Kenney 'Trick Tank", all the time. I would imagine the favorite TV show was 'Wagon Train' ![]() Don't you just hate PV544 red Volvo's. me too ![]() Paul |
Lee,
There was another wagon from upstate New York (Western region). A 1966 BelAir with a 427/390 HP engine. Yellow with American Mag wheels (charcoal-type). I believe it was another protested car, when it ran in D/S in 66'. Car ran in F/S in 68' (10.50-10.99 wt/hp). Then saw it again in 69'/70' running in SS/J. The car had a bunch of stuff hanging underneath it, wires and cables, and loose brackets. Still ran 12.50's, Not bad for #4170 lbs. Paul Last edited by Paul Ceasrine; 06-18-2010 at 10:46 AM. |
Lee,
Thanks for giving me the lead on the station wagons. Forgot a couple, don't know how,,, They Won Everything!!! PC |
OJ Hiding,
Yes, you can see the range of C/S in 1966. Weight bracket 9.50 - 10.59, very big GAP! From a 66' Chevrolet Biscayne (station wagon) 427/425 HP to a 66' Mustang (Hardtop) 289/271 HP (K-Code). Wonder what that looked like on the starting line?? On the 66' Hemi Charger for A/S. The Hemi Charger weighed in at #3895, and fell into the top-end of the A/S weight bracket (8.00 - 8.69), with an 8.65 wt/hp. The Hemi Belvedere and Hemi Coronet (sedan post-cars) weighed in at #3640 lbs. A much better weight break for A/S. Not only were the sedan post-cars #250 lbs. lighter, they were more rigid, because of the post design. The Charger was designed like the hardtop-coupe. The less weight and more rigid design was probably worth 4/10's quicker ET. The Hemi Charger was geared more towards Nascar. PC Last edited by Paul Ceasrine; 06-19-2010 at 11:00 AM. |
R/T,
*In 1966, at the Winternationals, Don Grotheer in a 66' Belvedere Sedan Hemi defeated Bill Jenkins in the 66' Chevy II for A/S. *At the Springnationals, Jere Stahl in his 66' Belvedere Sedan Hemi defeated Bill Jenkins * At the Super/Stock Magazine Nationals, Bill Jenkins won, defeating a 66' Chevelle Malibu SS396 B/S car. * At the Nationals at Indy. Jere Stahl defeated Bill Jenkins for Top Stock honors. * At the Wolrd Finals, Jere Stahl defeated Bill Jenkins for Top Stock. If you check out the ET's, you can see the 66' Belvedere Street Hemi sedan with 7" slicks and stock camshaft ran 11.90's. For the most part, if you took a stock 66' Hemi Belvedere 4-speed, put in 4.56 gears, headers and 7" slicks, you should have been able to get into the 12.80's. PC |
#6 | |
Banned
Liked 235 Times in 110 Posts
X-Tech,
Thanks, I meant to say NHRA-legal camshaft for A/S in 1966. Don't think you could run 11.90's with the factory.480/.460 bump-stick. Knew there had to be some trick with Grotheer and Stahl, leaving the line straight and not going up in smoke, and not sending out a driveshaft via=air-freight ![]() PC X-Tech, Did anybody in Mopar ever try to get the 1964 Plymouth Sport Fury or Dodge Polara cars legal with the early 64' 426/385HP (Nascar) Max-wedge engine into NHRA.. 11.0-1 pistons, Stage III Max-Wedge heads,.520 solid-lift camshaft, Nascar DP aluminum intake and single Holley Model #4160 (860cfm) w/center-feed inlet (part# 2532095) Would have fallen nicely into the 8.70-9.49 wt/hp break. Would have been a perfect A/Stocker for 1964/65, and B/Stocker for 66' instead of the over-rated 426/365HP Street-Wedge over-rated at 365HP. T The 426/385HP would have been one great street/strip engine. R/T. Max-Wedge Stage III heads had bigger ports, added bridging for the deck surface, 2.08 intakes/1.88 exhaust valves, crescent-shaped combustion chambers and the sides of the combustion chamber (intake side) cut for improved flow, as well as an additional 0-degree top dress angle on the valve seats, and the heat cross-over port removed/closed. An easy 40HP+ over stock cylinder heads. Last edited by Paul Ceasrine; 06-21-2010 at 01:22 PM. Reason: add-on |
