Old 06-24-2010, 06:15 AM   #1
JRyan
Liked 112 Times in 31 Posts
Default Re: Sleeveing a block
Alan,
Our blue SS/NA has a sleeved 350 block, NO FILL, and mounts on the side with welded stock mounts. We have over 300 passes on it, with the same bearings. We found a lifter going away, so we're going to freshen it again, but there is zero bearing material in the oil. It's not as fast as the purple car, but it's not nearly as trick either and it'll run 11.00's in good air, so it's no pooch. The point is, if your chassis is stiff enough, you won't have block problems.
I might add, the blue car has no bars forward of the firewall either, and we have never lost a bearing in that car in 13 years except for one mental lapse on my part -- got interrupted and forgot to put all the oil in. Whoops! But that block is still being used.
Jerry
Old 06-24-2010, 09:10 AM   #2
art leong
Can you sleeve all the bores in stock?
Art Leong 2095 SS
Old 06-24-2010, 09:31 AM   #3
Liked 1,909 Times in 427 Posts
Yes. Some of the older small bore stuff is impossible to find.
Old 06-24-2010, 10:42 AM   #4
randy wilson
Liked 22 Times in 22 Posts
If you pick the right sleeves and rings, it will actually pick up measurable H.P.
don,t have one
Old 06-24-2010, 10:54 AM   #5
FED 387
Liked 333 Times in 180 Posts
we have used Darton sleeves with success in many applications---Comp 387
Old 06-24-2010, 03:55 PM   #6
Todd Bailey
Liked 33 Times in 17 Posts
Had my engine builder tell me many years ago that if I brought him an engine run on rubber mounts and an engine run with steel mounts, he could tell which was which from looking at the mains. Rubber mounts and tie it down!!
Todd Bailey is offline   Reply With Quote
Old 06-25-2010, 12:36 AM   #7
Alan Warman
Jerry
Do you remember were you found the sleeves. Every body I talked to, keeps putting that custom word in front of the part number. Mellings has a sleeve but I do not think the O D is big enough. The bore size of the 350 is 4.057 and the sleeve is 4.062. So far LA Sleeves has the best price. So from all the info from every body. Between chassis flex and solid mounts is what killed the block.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 06-25-2010, 08:05 PM   #8
JRyan
Alan,
LA Sleeves is where I got mine. Not cheap, but they don't require any super trick cylinder wall finishes to get them to seal. The non-windowed block with these sleeves is plenty strong even for the 3550 lb. Superstocker with bumper draggin' wheelies, so you shouldn't have a problem as long as your chassis doesn't flex. Good luck!
Jerry
