Old 06-24-2010, 02:57 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Question Brake Pressure Switch
I am looking for a p# for the adjustable brake pressure switch that many are using in stock for there two step. I was told that Grainger sell a switch, that people are using, but I need a part #.
Thanks.
Robert
Robert Simpson is offline   Reply With Quote
Old 06-24-2010, 03:19 PM   #2
ron mattson
Liked 69 Times in 32 Posts
Default Re: Brake Pressure Switch
go to whitmancontrols.com they have what you need.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 06-24-2010, 03:21 PM   #3
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Robert
Is that legal??
MEXJOE is offline   Reply With Quote
Old 06-24-2010, 05:13 PM   #4
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
It is absolutely, positively, 100% legal. I showed the whole setup to Div. 1 tech man Ryck Campbell last year, or maybe the year before.
There seems to be a persistent belief that adjusting the pressure can act as a delay. Low pressure can indeed delay the rev-limiting function shut off, but the wheels will start turning as soon as the brake pressure gets below a certain point, regardless of whether the switch is still closed. The point of doing this is to get the 2 step switch open quickly and consistently, which requires getting the switch off before the wheels turn.
Robert- I'll get the part number when I get back to the garage this weekend.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 06-24-2010, 09:35 PM   #5
67ss
Here is a part number I got from from Alf Wiebe for a pressure switch he uses. It is a switch from GEMS Sensors. 209506. Here is a link to the switch on their web site:
http://www.gemssensors.com/CartAdd.a...tNumber=209506
Chad Harris
67 Chevelle SS
http://mysite.verizon.net/harrisracing
67ss is offline   Reply With Quote
Old 06-25-2010, 05:26 AM   #6
Robert Simpson
Thanks for the p#'s. Chad that is what I am looking for. Tony, I would appreciate the p# of the switch you use. I also have some questions about your set up. Thanks to all.
Mexjoe, yes it is legal.
Robert
Old 06-25-2010, 03:52 PM   #7
MEXJOE
MEXJOE's Avatar
Unhappy Re: Brake Pressure Switch
Robert
That's too bad...
I moved from bracket racing years ago,
just to get away from electronics
and delay devices?
Old 06-25-2010, 03:57 PM   #8
A pressure switch used to activate and deactivate a two step is not a delay device.
If I were going to use a pressure switch, I'd also use a brake pressure gauge when staging.
Old 06-25-2010, 09:03 PM   #9
Robert Simpson
Chad, you have a PM.
