Liked 59 Times in 13 Posts
Mike -
My dad has a set of Mickey Thompson tires that were recommended by them to use on his stick E/SM. I know there were several comp cars this weekend at Tulsa running Mickey Thompson radials. The tires he has are the 3074R 32.0/14.0R15. We have not ran them yet to give you an idea of if they work or not, but we will definitely be running them in the future. |
I bought a set of 1823's from Goodyear tire distributor Carol Shelby here in Phoenix, AZ just this year (probably February?). Although they are at the shop 75 miles away and I can't give you a date code, they were fresh or at least fresh enough.
It was Goodyear that told me a 3 year shelf life was acceptable. Rob Youngblood talked me into these 1823's as he loves them on his SS/J 'Vette. He tells me they will match 60' times with anything but will excel in the 330' and beyond. It's a lot bigger tire than anything I'm used to but I can't help but think they'll work for me. But nothing will help an old slick so I guess it's cha-ching time! And I'm not aware of radial tire success with a stick. If there is, guess it's a big secrete!
Jeff Lee 7494 D/S '70 AMX |
Liked 57 Times in 14 Posts
Vibration gone! Bell housing was twisted. After many futal attempts to straighten with no luck, purchased a new bell housing and now, smooth sailing once again. Thanks for all the tips and suggestions. Glad this saga is finally over. We went through 2 QuickData's, loose motor mount bolts, loose 3rd member bolts, metering rod hanger pin suck through the carb and many other "gremlins" due to the vibration. On to the next adventure!
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
Liked 11 Times in 8 Posts
Wow never heard of that one before. Glad you found it and good luck. Joe
Joe Buchanan SS/BX 3117 |
