Old 07-01-2010, 11:42 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: Nasty Vibration
I bought a set of 1823's from Goodyear tire distributor Carol Shelby here in Phoenix, AZ just this year (probably February?). Although they are at the shop 75 miles away and I can't give you a date code, they were fresh or at least fresh enough.
It was Goodyear that told me a 3 year shelf life was acceptable.
Rob Youngblood talked me into these 1823's as he loves them on his SS/J 'Vette. He tells me they will match 60' times with anything but will excel in the 330' and beyond. It's a lot bigger tire than anything I'm used to but I can't help but think they'll work for me.
But nothing will help an old slick so I guess it's cha-ching time!
And I'm not aware of radial tire success with a stick. If there is, guess it's a big secrete!
Jeff Lee 7494 D/S '70 AMX
Old 08-24-2010, 11:43 AM   #2
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Vibration gone! Bell housing was twisted. After many futal attempts to straighten with no luck, purchased a new bell housing and now, smooth sailing once again. Thanks for all the tips and suggestions. Glad this saga is finally over. We went through 2 QuickData's, loose motor mount bolts, loose 3rd member bolts, metering rod hanger pin suck through the carb and many other "gremlins" due to the vibration. On to the next adventure!
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 08-24-2010, 01:28 PM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
Wow never heard of that one before. Glad you found it and good luck. Joe
Joe Buchanan SS/BX 3117
