Liked 520 Times in 132 Posts
If you lightened a car 150 lbs what would the ave gain in ET be???
Liked 3,226 Times in 981 Posts
The approximate number has always been a tenth per hundred pounds, but there are variables of course....I always use the Wallace Calculators for quick reference and know many others do as well; here's the link
http://www.wallaceracing.com/Calculators.htm
I used following data on wallace
ET 10.05 MPH 130.00 at 3050lbs wallace says at 2900 lbs ET 9.88 MPH 132 and change Ok why then does NHRA list SS/G at 10.45 index SS/H at 10.50 SS/I at 10.55 etc difference in weight from H to I is 150lbs yet only 5 between indexes????????????
Liked 13 Times in 9 Posts
Because physics didn't create the index system.
![]() In my 4-cyl FWD car, 215 pounds was nearly HALF A SECOND, in the 1/8th mile! If I recall, a similar change in my Volare was about .12 in the 1/8th.
Liked 880 Times in 311 Posts
Good answer Michael.... Index system was created by Man and then hit/altered by man and his race cars performance!
Adger Smith (Former SS) Last edited by Adger Smith; 07-02-2010 at 09:31 AM. Reason: sp |
Liked 112 Times in 31 Posts
difference in weight from H to I is 150lbs yet only 5 between indexes???????????? Ed, the REAL reason stems from way back and the answer is two words: Danny Helmer. Jerry |
#7 | |
I can run SS/G-H-I just like you. Kind of makes it a difficult decision which to run, huh?
Jeff Lee 7494 D/S '70 AMX |
Jeff it doesn't make sense. H is at 3010. Why in the hell would you add 150 to get to I at 3160. So one guy was fast why did it effect all the indexes. Why didn't they hammer his combo? That's what they did to Robin Brown with the 283 stick in 07'
I guess that's just the way it is. Why don't you contact NHRA and see what can be done about it? Call NHRA Tech and ask for Pat Cvengros as he's the Committee Chairman of the S/SS Rules Committee.
Seriously, nothing will come of this posting here, you have to go to the source. While your at it, get the stick indexes in line with the automatic indexes. For example, there's a .200 spread between SS/J & SS/JA. That's ridiculous!
Jeff I did send a letter to NHRA a couple of years ago. They basically said to pound sand. My car needs to get the 299hp reduced. IHRA is 295hp. The 327/275 combo has been beat on for over 30 years. There's not alot left to be found in the horsepower dept. Were going to try a set of the RHS aftermarket heads this winter. But guess what the hp rating goes up to 304 when you do that. So well see.
